1998 Dodge Ram Leak
BBRANDON
Transmission problem
1998 Dodge Ram V8 Four Wheel Drive Automatic
I have a major leak from the inspection cover, I replaced the torque converter seal and it is still leaking bad
Nov 2, 2009 at 4:51 AM
CH112063
  • 1,320 POSTS
The leak may be from a couple other spots
1. any of the pump bolts may leak
2. The pump 'o' ring may be leaking
3 The pump, case, or converter may leak, in that order Yep, yep. If the pump bushing is worn,. you can't reseal it. Without putting a new bushing in.
The screws leaked almost as much as the seal.
Nov 2, 2009 at 11:47 AM
