1998 Dodge Ram how am i loosing oil
288,205 MILES • V8 • 2WD • AUTOMATIC
POOH84
i have change out oil pump and oil sending unit and pvc valve what alse can it be
Mar 28, 2010 at 8:09 PM
  • 75,988 POSTS
Either you are burning it in the cylinde due to valve seals/valves/rings/cylinder wear or you have an actual leak somewhere-check the front and rear seal of the crank, oil pan and valve covers and distributor O-ring
Mar 28, 2010 at 11:07 PM
