i have change out oil pump and oil sending unit and pvc valve what alse can it be
Mar 28, 2010 at 8:09 PM
✓Experienced Mechanic
Either you are burning it in the cylinde due to valve seals/valves/rings/cylinder wear or you have an actual leak somewhere-check the front and rear seal of the crank, oil pan and valve covers and distributor O-ring
