1998 Dodge Ram Heater problems
300,000 MILES • 6 CYL • 2WD • MANUAL
HORSEMAN1
My heater isn't working correctly; I only fill heat when the blower is on the lowest settings, when the truck is warm and sitting still. I checked the heater hoses and both are hot going into firewall. I have replace the themostat; collant level is full. I have replaced the blower motor. Is there anything I can do before I take the dash out?
Thank you
Roger Ault
Dec 16, 2009 at 2:53 AM
DOCFIXIT
  • 18,828 POSTS
Blend door cable maybe bent or out of adjustment. Can get to it under pass side may need to remove glove box.
Dec 16, 2009 at 3:09 AM
