98 1500 4x4 Ram was running fine then quit. Will not start. Will fire if fuel or starting fluid is introduced to throttle body. Have removed fuel tank & pump from tank. When pump is plugged back into wiring and ignition is turned on, pump will run then stop (fuel filter on top of tank has been removed during this process). ANY IDEAS?
Aug 12, 2009 at 12:11 PM
