1998 Dodge Ram engine will drop to idle
183,000 MILES • 6 CYL • 2WD • AUTOMATIC
BPOLLARD
I have a 1998 dodge ram with cummings 24 valve engine, sometimes when I start the engine it will drop to idle and will not rev up, until I wait, or switch it off. Sometimes even this does not work, but once it starts to run normally I do not have a problem for a day or two. The codes that have been pulled are throttle positioning censor, intake heaters, and communication problem. I replaced the throttle positioning censor, and it did not change anything, It has a new fuel filter, all of the mechanics that have tried to fix it have no idea where to look. I do notice that the problem seems to be worse when it is cold, or cold and wet. Could you give me any insight as to what to do?
Mar 5, 2008 at 4:30 AM
MASTERTECHTIM
  • 4,750 POSTS
thats a tricky one. the one thing i see in common is the ignition switch. without actually testing it, thats where i would start. the problems with the ignition switches is that so much current goes through them that over time they arc and cause carbon build up so once in a while the connection is lost. hope this helps
Mar 5, 2008 at 5:58 AM
