1998 Dodge Ram engine stalls at startup
105,000 MILES • V8 • 4WD • AUTOMATIC
SMIHAL
engine wants to stall at start up, it will run if you give it gas, but if not it wants to stall..i replaced the throttle position sensor but it still wants to stall, the fuel pump was new in the last 2 years. it drives fine once you are driving it just wants to stall at start up, once it is running for a minute it stays running.. this is a ram 1500 pick up with a 5.9 engine.
Aug 7, 2008 at 8:26 AM
MERLIN2021
  • 17,250 POSTS
Just a cold starts? if so it's probably the ECT(engine coolant tmp)sensor. But can also be the IAC(Idle air control valve).
Aug 7, 2008 at 8:37 AM
