1998 Dodge Ram engine oil leaking steady stream while runni
124,000 MILES • 6 CYL • 4WD • AUTOMATIC
RMKER
I have 98 dodge ram pickup w/ cummins 5.9 turbo diesel. While pulling into work this am I noticed oil leaking on the ground and wet look under front of engine and diffential areas. after further inspection I see the oil coming from the power steering pump shaft?? yes power steering pump. it seems to be mounted to an engine oil source? Please help, I am out of commision. Thanks for your time. Chuck
Oct 20, 2010 at 7:20 AM
  • 110,248 POSTS
Chuck:
Are you sure it is motor oil and the pump seal hasn't gone bad?
Oct 20, 2010 at 3:28 PM
