HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Ram
Engine
Symptoms
Not Running
SPONSORED LINKS
1998 Dodge Ram Does not start
STINGRAY65
MEMBER
1998 DODGE RAM
Electrical problem
1998 Dodge Ram V8 Two Wheel Drive Automatic
Will A PO122 Throttle/pedal Senser/switch A Circut
Low input Keep the motor from starting
Sunday, July 11th, 2010 AT 3:37 PM
MECHANIC
Will it start with the throttle pushed?
SPONSORED LINKS
Sunday, July 11th, 2010 AT 11:41 PM
STINGRAY65
MEMBER
Wednesday, July 14th, 2010 AT 4:44 PM
MECHANIC
Check wiring to the TPS to make sure everything is clean and tight. Also, check for breaks in the wiring to it.
Friday, July 16th, 2010 AT 11:42 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1998 Dodge Ram Fails To Start
The Truck Runs Fine. I Can Start The Truck And Drive It All Over Town And Run My Errands All Day Long For Weeks And Then Out Of The Blue...
Asked by
settle789
1998
DODGE RAM
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1998 Dodge Ram Will Not Start
1998 Dodge Ram 1500 4wd 5.2l Automatic Will Not Start But The Ignition Does Turn Over. New Battery In Place Also. It Does Not Fire At All...
Asked by
berrio3443
1 ANSWER
1998
DODGE RAM
1998 Dodge Ram 98 Dodge Ram Cranks But Will Not Start
1998 Dodge Ram 1500, 5.2 Liter, Cranks But Will Not Start. Obd Codes Are P1388 And P0320. With Ignition Switch On, No Voltage To Coil....
Asked by
Randall Breaux
1 ANSWER
1998
DODGE RAM
1998 Dodge Ram Engine Will Not Start
(5.9l Fuel Injected All Original) Truck Was Running Fine Throughout A 450 Mile Road Trip. Truck Was Shut Off For Less Than 5 Minutes At My...
Asked by
ssojoat
1998
DODGE RAM
Pickup Will Not Start.
I Have A 1998 Dodge Series 3500 Pickup Truck With A V-10 Engine. The Truck Ran Perfect Until I Let A Friend Use It. The Bottom Rad Hose Fell...
Asked by
BigcrazyMike
1998
DODGE RAM
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
