Still have a coolant leak in front part of engine? Intake gasket?
76,000 MILES • V8 • 2WD • AUTOMATIC
MPM359
Replaced water pump, thermostat gasket and housing. Still have a coolant leak in front part of engine? Intake gasket? Would steel seal fix this problem?
May 12, 2010 at 8:14 AM
  • 110,251 POSTS
Chances are it is the intake or the timing chain cover. Products that are designed to seal leaks usually cause other problems. Often times they will plug a heater core. Thus, I don't recommend it.
Go to the local parts store and ask if they will lend or rent a pressure tester and pressure test the cooling system. Pressure test the system to see if you can identify where the leak is. Also, they make a dye you can put in the system to check for leaks. WHen you shine a black light on it, it glows. You can try either.
Let me know what you find.
May 13, 2021 at 5:16 AM
SQM
  • 6,383 POSTS
Pressure testing the cooling system can help determine the issue.
Here is a helpful guide:
https://www.2carpros.com/articles/radiator-pressure-test
As mentioned by Joe using a dye can definitely make it easier to find a leak.
I have attached the replacement procedure for the intake gasket and timing cover below for your reference.
Dec 12, 2021 at 11:37 AM
