1998 Dodge Ram changing motors
THOMAS97CADILLIAC
Engine Mechanical problem
1998 Dodge Ram Four Wheel Drive
i want to buy a 98 dodge pickup 4x4 that has no motor, no trans; i want to know if the motor and trans out of a 98 dodge durango will interchange? i can get a different computer or whatever it takes. i was wanting to go with the 5.2? 318 dodge motor and was told that the motor will work out of a durango, jeep, or pickup, but the trans would have to b from a 98-00 pickup? can u help?
Oct 10, 2010 at 4:11 PM
  • 110,251 POSTS
the engine will fit. However, the trans will not. You need to get one for the truck. As far as replacement parts, we always recommend direct fit components because there are so many things that may not work out for you. Sensor can be different, vacuum hoses, wiring, computer, mounts... The list goes on. What I recommend is to find the correct engine and trans for the truck. That way, you will save money in replacing parts, and you will save a lot of time.
Oct 11, 2010 at 4:13 AM
