1998 Dodge Ram air flow to the vents or floor
CAPTKIRK19
Interior problem
1998 Dodge Ram V8 Two Wheel Drive Automatic
When I turn my a/c on,and the dial to the vents or to the floor,it defaults to defrost.When I put the dial to heat,and put the dial to floor,it comes out the vents and floor.So I know my servos are working.So what else could this be,my air will not flow to the right location I select on my dial.This is all vacuum,no electric.
Aug 15, 2010 at 12:19 PM
  • 110,244 POSTS
Have you checked for vacuum leaks under the dash? Also, the control panel that controls the direction? To me it sounds like a vacuum leak.
Aug 15, 2010 at 3:17 PM
