1998 Dodge Ram abs light and brake light
176,000 MILES • V8 • 2WD • AUTOMATIC
209MIKE
i was just wondering what would cause my abs light and break light to go on at the same time i checked the break fluid and it is fine and i dosnt feel like there is air in the lines the came on after i did my upper ball joints
what would cause those lits to go on
thanks mike
Jan 27, 2010 at 10:48 AM
  • 110,246 POSTS
Check to make sure you didn't disconnect or damage an ABS sensor when you replaced the ball joints. Also, recheck the brake fluid to make sure it hasn't dropped.
Feb 2, 2010 at 2:45 AM
