1998 Dodge Ram '98 ram with driving problems
SHELTON13
Engine Performance problem
1998 Dodge Ram V8 Two Wheel Drive Automatic 118 k miles
alright, i have a '98 ram that seems to drive funny. it seems to shift fine, but in second gear it has a hickup and continues to shift ok. then after driving on the highway for about 15 minutes, the rpms start fluctuating, a grinding news comes from the truck (not sure where) and then it dies on me. but it was start right back up fine...and die again. ive been told that it could be the transmission, fuel pump, or even a sensor...can you help me out?
Sep 9, 2010 at 5:59 AM
  • 110,246 POSTS
The transmission won't kill the engine. Has the check engine light come on? Have you checked fuel pump pressure when this happens?
Sep 10, 2010 at 12:31 AM
SHELTON13
Well the check engine light has never come on...and I don't know how to check the fuel pump pressure...
Sep 10, 2010 at 9:54 AM
  • 110,246 POSTS
Here is a how to for checking fuel pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a fuel pressure gauge, but most parts stores will lend or rent them to you.
Let me know what you find.
Sep 10, 2010 at 5:28 PM
