1998 Dodge Ram
LAROCHE1
1998 Dodge Ram V12
How to change blower motor in a 98 dodge ram
Dec 18, 2009 at 8:18 AM
  • 110,248 POSTS
I was able to get this off the net. Let me know if it helps or if you need specific help.
Removal of the blower motor on these models requires that the A/C lines be disconnected. According to law, refrigerant must be captured and reused which requires the use of special equipment and training. This procedure MUST be performed by a certified MVAC technician.
1.Disconnect the battery negative cable.
2.Remove the instrument panel.
3.Recover the refrigerant. See "Note" above.
4.Disconnect the liquid line refrigerant line fitting from the evaporator inlet tube.
5.Disconnect the accumulator inlet tube.
6.Drain the cooling system.
7.Disconnect the heater hoses from the heater core tubes.
8.Remove the four nuts from the heater-A/C mounting studs on the engine compartment side of the dash panel.
9.Remove the nut that secures the heater-A/C housing mounting brace to the stud on the passenger compartment side of the dashboard.
10.Pull the housing rearward far enough for the mounting studs and evaporator condensate drain tube to clear the dash panel holes.
11.Remove the housing from the vehicle.
12.Remove the three screws that secure the motor to the housing.
13.Remove the wheel, if desired, by removing the clip from the motor shaft.
14.Installation is the reverse of removal. Note the following points:
A.When installing the wheel onto the shaft, be sure to line up the flats.
B.The ears of the retaining clip must be on the shaft flat.
C.Be sure the blower motor seal is in place.
Ram
The blower motor is located on the passenger's side beneath the dashboard.
1.Disconnect the battery negative cable(s).
2.Disconnect the blower wiring after disengaging the wiring harness from the retainer clip.
3.Remove the blower motor cooling tube.
4.Remove the hardware securing the blower motor and wheel assembly to the heater-A/C housing.
5.Remove the blower motor assembly.
6.Remove the wheel, if desired, by removing the clip from the motor shaft.
7.Installation is the reverse of removal. Note the following points:
Dec 22, 2009 at 5:06 AM
