1998 Dodge Ram
MANDIE1
  • 6 POSTS
Engine Performance problem
1998 Dodge Ram V8 Four Wheel Drive Automatic
I have a 1998 Dodge Ram and on the dashboard there's a light that turns on that says Check Engine. What is the problem?? What can I do to fix it.
May 12, 2010 at 3:13 PM
  • 31,937 POSTS
Hi there,
This is an indication that there is a set fault cone in the ECU, you need to go get a scan done to read this code, the code will be an indication as to the actual fault, start here.
mark (mhpautos)
May 12, 2010 at 5:35 PM
