1998 Dodge Ram
250,000 MILES • V8 • 4WD • AUTOMATIC
FORTYGRIT39
My truck is hesitating/cutting out, at all speeds, intermittently. Causing me to have to pull to the shoulder sometimes and wait for it to clear up. Sometimes I can drive for over 200 miles with no issues other times it will act up 5 times in less then 20 miles. I checked the codes and there was nothing that would pertain to this type of problem. I cleared the codes and the truck hesitated and did not throw any codes at that time. It's hard to tell if it is fuel related or ignition. It does pop through the air intake at times. I am not sure where to start looking! One more thing, if I put the truck in neutral while the problem is happening I can rev the engine and it sound fine, but putting it into drive and trying to go it has no power and sounds like it is going to die.
Nov 19, 2008 at 6:52 AM
BMRFIXIT
  • 19,053 POSTS
Any codes should be investigated as it may be related directly or indirectly to your problem
I would check fuel pressure and fuel pump
if you have good pressure disconnect O2 sensors and drive around and if u feel improvement replace the sensors
good luck and let me know
Nov 19, 2008 at 9:43 AM
