1997 Dodge Ram Wont Run Right
1997 DODGE RAM
175,000 MILES • V8 • 2WD • AUTOMATIC
RYAN12387
I was driving the other night hope stopped at a stop sign and went to give it gas it would go but didnt have the power to get up and go. Came outside the next day to try and find the problem and its got worse to keep the truck running u have to push the gas all the way to the floor and it dont go over 2,000 rpm. Checked fuel to rail got good pressure and have spark. Any ideas what the problem could be?
Jun 21, 2010 at 1:58 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 21, 2010 at 5:29 AM
RYAN12387
tryed most of that replaced fuel pump regulator checked spark truck turns and fires want to start but keeps flooding its self out changed plugs starting to get stumped gonna take the map sensor to have it tested but running out of ideas. anymore ideas?
Jun 24, 2010 at 1:44 PM
