1997 Dodge Ram water in passanger floor board
TARJIJ73
  • 1997 DODGE RAM
Air Conditioning problem
1997 Dodge Ram V8 Two Wheel Drive Automatic
i have already changed heater core, and I still have a problem with water in the floor board. Is it now the a/c? And how do I fix it?
Tuesday, June 15th, 2010 AT 9:22 AM
CARADIODOC
  • 34,373 POSTS
Check the drain hose for blockage on the passenger side front of the firewall. If squeezing it doesn't clear it, squeeze the wire ring to remove the hose, then carefully poke a pencil into the drain tube.
Caradiodoc
Thursday, June 17th, 2010 AT 4:55 AM
