1997 Dodge Ram Slipping while in drive
116,000 MILES • V8 • 4WD • AUTOMATIC
SHARI14
1997 Dodge 2500 has been slipping while in drive seems worse as you are slowing to a stop. Have replaced the speed sensors am just wondering if the overdrive button is bad or does the tranny need to be replaced or rebuilt
Jul 24, 2010 at 10:39 AM
  • 110,248 POSTS
If the transmission is slipping, either the clutches are worn, it could be low on trans fluid or the filter may be partially plugged.
Is the fluid clean and full?
Jul 24, 2010 at 3:35 PM
SHARI14
Yes it is full on fluid. The funny thing is if you manually shift this truck there is no problem, leads me to believe that this is an electronic problem not a tranny problem...
Jul 26, 2010 at 1:49 AM
  • 110,248 POSTS
When you manually shift, bands are forced to assist to hold it in gear which may prevent some of the slipping
Jul 26, 2010 at 3:41 PM
