1997 Dodge Ram Problem after Problem
165,000 MILES • V8 • 4WD • AUTOMATIC
PROBLEMATICDODGE
My engine is lacking power and makes a hissing noise when accelerating. The power to the wheels is bare minimum. My check engine light came on and I am fed up with costly repairs. can you help me please diagnose this issue....
Jun 22, 2009 at 5:52 PM
  • 31,937 POSTS
Hi there,
The hissing may be a vacuum leak, this can cause your particular problem, get a scan done to check the set fault code in the ECU, the check light is a visual indication that there is a code set.
Mark (mhpautos)
Jun 23, 2009 at 12:53 AM
