1997 Dodge Ram No Power
220,000 MILES • V8 • 4WD • AUTOMATIC
JAMESFLOYDEVANS
My truck has no power. Runs fine at an idle up to just over 2000 RPM. Scanner is giving fuel mix a negative reading. I hav an inc catayst and fuel system reading.
I changed the MAP sensor which made no difference. What should I check next?
Nov 2, 2010 at 10:36 PM
  • 75,988 POSTS
If its not an engine mechanical or transmission problem could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Nov 2, 2010 at 11:24 PM
