1997 Dodge Ram Missing Out
99,800 MILES • V8 • 4WD • AUTOMATIC
DODGE COUNTRY BOY
My Truck Is A Dodge Ram 1500 V8, Problem In The First Say With In 10 Minutes Of It Running It Will Miss Out Almost To A Die Then Itll Quit Missing Out and Be Fine Then If I Turn It Off And Start Drivin Again Itll Start Missing Out Again,...Say Im Going 45 And It Starts Missing Out Drop To Around 35-40 And Itll Stop Missing Out.
Apr 4, 2009 at 12:17 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Apr 4, 2009 at 12:52 PM
