1997 Dodge Ram low idle 200rpm
13,500 MILES • V8 • 4WD • AUTOMATIC
MOPARMAN85
i have a 97 dodge ram 1500 318 4x4. my truck doesnt have a rampaging idle like most problems out there. it fires up idles normaly then when i go to put it in drive it idles at 200rpm. it used to start up and idle all over the place and shut off. that was problem was fixed when i replaced the iac. i have a new fuel canister evap valve sensor. last winter i replaced both sensors that hang above the transmission pan. i just cant get to the bottom of this. i need my trucks balls back, thanks
Sep 8, 2009 at 7:16 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Milage is 135K ? Plugs, wires, coil , Dist all good?
Has PCM been scanned? What is engine compression? Fuel pressure?
Sep 8, 2009 at 7:41 AM
