1997 Dodge Ram Idle issue
176,000 MILES • V8 • 4WD • AUTOMATIC
ROGER32327
Every 6 seconds my idle goes up about 600 rpm and then drops to about 300 and almost stalls out and sometimes it does stall. I have replaced the IAC, TPS, purge valve, charcoal canister, and air cleaner gasket. I can not figure out what is causing the IAC to open and close every 6 seconds. Please help
Oct 22, 2009 at 1:45 PM
  • 110,248 POSTS
Have any other codes come up on the computer? Also, have you checked closely for vacuum leaks? Does it seem worse hot or cold or doesn't it matter?
Oct 26, 2009 at 3:47 AM
