1997 Dodge Ram help
87,000 MILES • V8 • 4WD • AUTOMATIC
MCHEWY
i have a 1997 dodge that was acting like it was loading up on fuel replacer fuel lines tank pump filter and it thru a code for the throttle posioning sencer so replaced it and no change now it has no fire to or from the coil pack im lost and dont know were to fo from here so any help or ideas would be great thank u
Apr 24, 2010 at 12:36 PM
  • 110,248 POSTS
Check the wiring harness where it plugs into the PCM. Check to make sure it is tight and not corroded.
Let me know what you find.
Apr 24, 2010 at 3:32 PM
