1997 Dodge Ram fuel pump
1997 DODGE RAM
120,000 MILES • V8 • 4WD • MANUAL
KRALLING608
I am not getting any fuel to the cylinders, the fuel pump works, I was wondering If the fuel pressure regulator/filter connected to the fuel pump could suddenly clogg up? thank you
Feb 2, 2008 at 2:52 AM
Check the fuel pressure with a fuel pressure gauge-make sure its within specs. If okay-start by looking for a constant spark.
The computer might not be getting an ignition reference signal and not energizing the injector/s-could mean a problem with the distribtuor pick-up, camshaft and crankshaft sensors.
Feb 2, 2008 at 5:26 AM
