Fuel Filter?
155,000 MILES • V8 • 4WD • AUTOMATIC
GARYBFLO
OK, seeing that my truck does not have a fuel filter, what is the black canister that is on the frame rail that seems to have a line-in and line-out from the gas tank. I am getting a fuel smell coming from this.
Feb 18, 2010 at 9:26 PM
  • 110,251 POSTS
You do have a filter, but you need to remove the fuel tank to replace it. Here are the instruction to do so in the diagrams below with a guide to help walk you through the repair.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Feb 19, 2010 at 1:43 AM
PUNKIN17CHEF
while driving my truck just cuts off. i think i might have a bad fuel filter and or a bad fuel pump but after the truck sits for a while it will crank back up but the problem still occurs help please any all thoughts welcome.
Aug 27, 2020 at 5:09 AM (Merged)
  • 110,251 POSTS
Here is a how to for checking fuel pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
MRCHIEFSMAN
where is the fule filter located?
  • 110,251 POSTS
It is on top of the fuel tank. It is part of the regulator. Here is a picture of it.
https://images.2carpros.com/forum/automotive_pictures/249084_fuel_filter_1.jpg
Let me know if this helps. Joe
GEAR_HEAD26
A friend of mine has a 1997 dodge ram 1500 with a 360 V8, four wheel drive and it does not have a sport package. Everytime we start it it takes usually two tries to get it to fire. We think it could have something to do with the fuel filter. How do we get the fuel pump off to either replace the pump or the filter? And if possible please have a diagram so we can get an idea on how much work is required.
CARADIODOC
  • 34,415 POSTS
The filter is on the frame rail, not in the tank. I have never heard of someone solving a starting problem by changing the filter.
There have been a lot of problems with the ignition switches getting burned contacts or overheated terminals and melted connectors. The next time it doesn't start, watch what's happening on the instrument cluster. The circuit that usually causes trouble feeds the radio, cluster, and heater fan. I don't believe I've ever heard of a no-start condition, but that's what it sounds like.
On the other hand, if there is a fuel injector leaking pressure down over night, there will be a long crank time. Try turning the ignition switch to "Run" for a few seconds, then off for a few seconds, then cranking it. Every time you turn the switch on, the fuel pump will run for two seconds to get the pressure up. If it starts better, it could also be a leaky pressure regulator or check valve in the pump. Neither of those are serious.
caradiodoc
NATHANLEE
1997 Dodge RAM 1500, 80,000 miles, 5.2 L:
Is the fuel filter located inside the fuel pump? If so, do I get a new filter when I buy a new fuel pump? - Thanks
MERLIN2021
  • 17,250 POSTS
No it's above the gas tank.
BILL MCCARTHY
I have a 1997 Dodge Ram with the Cummings Turbo Deisel vin # 3b7kc23dovm516101. My electric fuel pump went bad, but i cant seem to find it. It is an external fuel pump.
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel transfer pump is located on the left side of the engine and above the starter motor.
The fuel filter is located under hood, driver side, lower engine area, mounted in fuel line
EARL909
Engine Mechanical problem
1997 Dodge Ram V8 Two Wheel Drive Automatic
I CANNOT FIN THE FUEL FILTER ON MY TRUCK AND WAS WONDERING IF YOU COULD TELL ME WHERE IT IS?
JDL
  • 16,098 POSTS
Welcome, my info says it is mounted on top of fuel pump module, the module in the gas tank.
BARRY SCHUNK
My truck cut out, started to back fire and will not start. It is as if it's starving for fuel. Where is the fuel filter located?
JDL
  • 16,098 POSTS
I believe the pressure regulator and filter are on top of the pump assembly. The regulator and filter may be one assemble, the parts book shows it is replaceable.
I'd check fuel pressure before I did anything.
PAUL ANDERSON
Alright, so I was driving down the road and I ran out of gas and I just so happened to have a can of gas in the bed of my truck so I poured that in the tank really quick, started it up and continued on my way about a mile down the road it started sputtering and coughing. the check engine light came on then it quit running or ran out of gas so I thought. so I walked to the nearest gas station with gas can in hand get back poured it in long story short, I finally got it running after a few cans of gas were agreed and some starting fluid. but now it's been running really rough and acting like it's going to shut off on me again. so I figured it's probably time to clean the fuel filter out. So where is that darn thing, anyone?
Aug 27, 2020 at 5:10 AM (Merged)
The filter is part of the fuel pump module. I included the process to replace it. Unfortunatley you need to drop the tank.
This does sounds like a fuel issue and I suspect the fuel you put in at some point was "dirty" or the container it was in had some contamination. If this is the case, you will need to drain the tank and replace the pump but I would make sure you clean out the tank as well.
EBBIE05
Is it difficult to change the fuel filter on 1996 Dodge 3500...cummins diesel
INTERNETMECHANIC
  • 700 POSTS
The procedure looks straight forward to me.
https://images.2carpros.com/forum/automotive_pictures/512072_ram_diesel_fuel_filter_1.jpg
SHERLOCK666
my truck starts and runs fine. I calculate the gas by mileage and always guess low just in case. When i get down to around 30 miles (2-3 gallons) it starts to studder and shake real bad. And i cant excellerate and eventually i coast and turn it off and then im stranded. I've been told that it's the fuel filter but comon sence says that no matter how much gas is in it the filter would act up. If there was dirt being sucked up when the gas is low it would get stirred up when i put gas in, therefore acting up imediatly. It doesent. The pump is still working since i can hear it kick it on when the key is turned on.
P.s. the gas gage doesent work, thus i calculate mileage.
P.s.s. I took 4 years of auto shop in high school so i know a few things
  • 75,988 POSTS
When the last time you gave it a tune-up
Possible causes:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
JSWAIN
  • 24 POSTS
Might be water in gas. I would fill tank with good gas and use a water remover such as heet, etc.and see if that helps before I did anything else.
JAMES596
how do you change the fuel filter on a 1996 dodge ram 1500 pickup
JDL
  • 16,098 POSTS
Welcome, the filter is part of regulator assembly, sits on top of fuel pump module.
https://images.2carpros.com/forum/automotive_pictures/170934_dodge_fuel_filter_1.jpg
LUCIA62KOOL
Engine Performance problem
1996 Dodge Ram V8 Two Wheel Drive Manual
Where is the fuel filter on my Dodge 3500 Ram diesel engine?
JDL
  • 16,098 POSTS
Welcome to the forum, underhood driver side of engine.
https://images.2carpros.com/forum/automotive_pictures/170934_diesel_fuel_filter_1.jpg
CHICO23
  • 39 POSTS
Were is the fuel filter of a 96 dodge ram van with 203,806 miles
BLACKOP555
  • 10,386 POSTS
follow the fuel ines from the gas tank. best way to tell you where it is located.
MANDIE236
1996 Dodge Ram V8 Four Wheel Drive Automatic
I have a Dodge Ram 1500 year 1996. I would like to know where the fuel filter is located.
  • 75,988 POSTS
1996 Dodge Truck RAM 1500 Van V8-318 5.2L Magnum Fig. 1 Top View Fuel Pump Module - Gas Powered Engines - Typical
https://images.2carpros.com/forum/automotive_pictures/12900_fuelfit_1.gif
A combination fuel filter and fuel pressure regulator is pressed into a rubber grommet located on the top of the fuel pump module. A separate frame mounted fuel filter is not used.
