1997 Dodge Ram ABS Warning light
165,000 MILES • V8 • 2WD • AUTOMATIC
NUKEM463
My 97 Ram has rear-wheel ABS. My brakes have been shaking for about the past week, especially when slowing from high speed. I figured the rotors got warped and planned on replacing them this weekend. However, yesterday, the brake pedal went soft (all the way to the floor almost before engaging) and the ABS light came on. The fluid level is OK - above minimum, but not full. Could the rotors have caused this or is there another problem with the ABS?
Oct 29, 2010 at 2:18 AM
  • 110,244 POSTS
Did you hear the ABS actuator engage? If not, it sounds like there is a leak or the master cylender is bad.
Oct 29, 2010 at 3:43 AM
