Heater vent Problem?
97RAMFAN_2010
Heater problem
1997 Dodge Ram V8 Four Wheel Drive Automatic 171k miles
hi I have a 97 ram and i cannot figure this out, my heat always worked good and eveything in the past, and for the past couple years no matter what setting i put it on the heat only blows out of the vents on the dash by the windshield (Defroster vents). no Air is blown out of any of the other vents any suggestions?? thnxs
Nov 23, 2009 at 9:28 AM
JSWAIN
  • 24 POSTS
You most likely have a leak in one of the vacuum hoses. Check the hoses in engine compartment between firewall and intake manifold first to see if they are leaking. There are also one-way check valves (2 I think) in those vacuum lines. Make sure they are working properly (you should be able to blow through them in one direction only).
Nov 23, 2009 at 1:33 PM
97RAMFAN_2010
ok thank you i will look into this and see if this may be the problem iam having and get back to you thanks again.
Nov 26, 2009 at 12:27 PM
