1996 Dodge Ram wont start
180,000 MILES • V8 • 2WD • AUTOMATIC
JJ3922
My truck has the 5.9 engine and ran great. One day it died on the highway and will not start. It will turn over fine but has no spark. I have changed the cap, rotor, coil, plugs, wires, and crank sensor. It still will not start. The is no spark from the coil. I hooked up a code tester and it does not even read the vehicle. When I turn the key, the check engine light does not even light up (not sure if it did before it broke down). I have done a quick check on fuses and zi think they are all ok, but I will check further. Does this sound like the computer is shot or something in the distributor. I have read of other changing a cam sensor but I am not sure where it is. Also, I have been told it may be the ignition module, but when I search for the part online I get that it doesn't apply to my vehicle. Please HELP!!!
Jun 8, 2010 at 6:49 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 4, 2018 at 3:34 AM
ALEXIO
  • 5 POSTS
Also
