1996 Dodge Ram Won't start
1996 DODGE RAM
191,000 MILES • V8 • 4WD • AUTOMATIC
SULLIVAN871
My 1996 Dodge Ram 1/2 ton dies and won't restart. Replaced IAC valve, and fuel pump checks OK. Still, no start. Cranks fine though, but code readers will not communicate with computer. Crankshaft sensor bad?
Jul 1, 2009 at 9:43 AM
BMRFIXIT
  • 19,053 POSTS
Key on engine off
do you have check engine light on (you should )
if not check fuses and wiring ,relays
if light on
crank engine light should go off if not suspect bad crank sensor
Oct 4, 2018 at 3:35 AM
