1996 Dodge Ram will not idle
BRETT DUNCAN
Engine Mechanical problem
1996 Dodge Ram V8 Four Wheel Drive Automatic 105K miles
The truck will run fine as long as you keep your foot on the throttle. If you let off the throttle it will die imediately.
Mar 10, 2008 at 11:12 PM
GREASEMANEDDIE
It sounds like the most probable cause of your problem might be a vacuum leak. You need to get someone to crank the vehicle and keep it running while you listen under the hood for a hissing noise. YOu probably have a vacuum line that is busted or has come loose.
Mar 14, 2008 at 12:40 PM
