1996 Dodge Ram wheel bearing
B.JONES06
Suspension problem
1996 Dodge Ram V8 Four Wheel Drive Automatic
can u show me a diagram for my front wheel bearing assembly? How do i change the bearings and what to look for that might be damaged by bad bearings
Jun 13, 2010 at 2:47 PM
BMRFIXIT
  • 19,053 POSTS
Raise and support vehicle.
Remove wheel.
Remove caliper retainer and anti-rattle springs (if equipped).
Remove brake caliper, and support it aside.
Remove rotor and axle hub nut.
Remove wheel bearing and hub assembly hub-to-knuckle bolts.
Remove wheel bearing and hub assembly from steering knuckle and axle shaft.
Remove brake dust shield.
To install, reverse removal procedure.
Tighten retaining nuts and bolts to specification
Jun 13, 2010 at 3:17 PM
