1996 Dodge Ram WHAT IS WRONG ???
216,485 MILES • 6 CYL • 2WD • AUTOMATIC
CHICO23
  • 39 POSTS
WELL I HAVE A 96 DODGE RAMVAN 1500 V6 LITER.
THE CAR WAS WORKING AND RUNNING IN GOOD PREFECT CONDITION, ONE DAY AFTER LEAVING WORK THE CAR DIDN'T START AT ALL. I HAVE RECENTLY CHANGED THE OIL, FILTERS, OIL SENDER, FUEL PUMP, SPARK PLUG CABLES, AND THE TWO SENSOR ON THE CARBUTOR. THE CAR CRANKS BUT DOESN'T START, AND U CANT HEAR THE FUEL PUMP WHEN IDLING. PLEASE HELP ITS MY WORKING VAN. THANK YOU!
Mar 28, 2009 at 12:11 PM
BLAKESFIRSTT
  • 32 POSTS
Well i guess the first thing would to check and see if u have spark to your plugs. Then make sure there is gas going into the carb. check those and let me know what u get.
Mar 28, 2009 at 12:53 PM
CHICO23
  • 39 POSTS
WELL THERE IS SPARK GOING ON, SO THEN I TRIED PUT SOME GAS ON THE CARB AND IT START BUT THEN STOPPED. SO I THOUGHT IT WAS THE FUEL PUMP NOT WORKING. SO I WENT BACK TODAY TO PICK THE CAR UP AND I TRIED TO START IT AND IT DID, SO I DON'T KNOW WHAT IS HAPPENING
Mar 29, 2009 at 8:51 AM
BLAKESFIRSTT
  • 32 POSTS
Well Im not familier with your fuel system....but if its like my 98 i would check the fuses and replace them just to be sure then go to the relay box and replace that one......and if it still acts up i would get a tester and pull the pump out again and check the current going to the pump......and if all thats good i would return the pump and get a new one
Mar 29, 2009 at 9:53 AM
