having problems keeping the truck idling?
130,000 MILES • V8 • 2WD • AUTOMATIC
SAM121170
I have a 96 Dodge Ram recently I am having problems keeping the truck idling after it warms up it runs fine when it is cold I have checked the engin codes and have found code# 14 engine coolant stays cold too long and code # 17 low voltage at map sensor any feedback would be appreciated Thank you
May 24, 2008 at 4:19 AM
LEGITIMATE007
  • 5,121 POSTS
yes, you'll need to change your ect(engine coolant temp.sensor) and your mapp sensor.but first on the mapp sensor check the harness to make sure your getting the correct amount of voltage, which should be around 1 to 5 volts.
Jun 1, 2019 at 8:08 AM
