1996 Dodge Ram spark plugs
186,000 MILES • V8 • 2WD • AUTOMATIC
RONNIE M.
my truck keeps fouling the plugs and seems to be running overly hot even though the temp. gauge reads normal.i have replaced plugs,wires,rotar and cap.thermostat,radiator, and water pump are fine
Aug 2, 2009 at 4:36 AM
  • 110,248 POSTS
Has the check engine light come on? Also, how are the plugs fouling, fuel, oil...?
Aug 8, 2009 at 3:44 PM
SLEDJOCKEY
You missed the other part of the equation:
What has been done to the intake? If you are fouling plugs and it is running hot, you are not getting the right air/fuel mixture.... Possibly. Good next thing to check.
Aug 9, 2009 at 7:54 AM
  • 110,248 POSTS
Yes, I understand what you are saying. At this point, I'm trying to determine where the problem is coming from. It could be a compression problem.
Aug 9, 2009 at 4:13 PM
SLEDJOCKEY
Do a quick compression check and that will tell you if that is the cause......
Just follow the fuel route and check each segment:
Suck, squeeze, bang, blow.......
Suck comes first and is usually forgotten.
Aug 10, 2009 at 2:00 AM
