1996 Dodge Ram shifting
231,116 MILES • V8 • 2WD • AUTOMATIC
KENDEMO
While driving my truck, i smelled something like an electrical burning smell briefly. Soon after my transmission would not shift into third or fourth gear on its own. I changed the atf and filter. I did not find any shavings or anything wrong with the transmission. Is there a sensor that could have burned out?
Apr 13, 2008 at 2:10 AM
MERLIN2021
  • 17,250 POSTS
There should be a fault code stored if thats the case, autozone will read the codes free, post the codes here...
Apr 13, 2008 at 2:15 AM
SERVICE WRITER
  • 9,123 POSTS
The smell may be a clue, check all the wiring to and from the transmission including connectors looking for a possible wiring issue. Should check the codes to see what is in there to help narrow down the source.
That transmission requires the atf+4 fluid NOT dextron.
Apr 13, 2008 at 2:18 AM
