1996 Dodge Ram return line fluid pressure at idle
160,000 MILES • V8 • 2WD • AUTOMATIC
LARRYD
i have a 96 ram 1500 with a 5.2 and a 46re 4spd
overdrive,i removed the trans fluid return line at idle hot and the fluid was at a very slow trickle- what should the trans fluid pressure be at the return line from the radiator at idle ?,also is their a check ball in the trans fluid delivery line to the radiator,never had a trans flush/purge ,
seems to be alittle weak at acceleration but then shifts fine .any info would help,thanks.
Jul 29, 2010 at 5:47 AM
KHLOW2008
  • 41,812 POSTS
Hi larryd,
Thank you for the donation.
There is no specific pressure at the cooling lines because there are no check valves or pressure point. The fluids passing through the radiator are for cooling purposes only.
If the acceleration is poor with proper shifting, it is more likely to be from the engine rather than the transmission. If there are any problem with transmissions,it would most likely be slipping rather than underperforming.
Jul 29, 2010 at 6:53 AM
