1996 Dodge Ram Recently flooded the engine
135,000 MILES • V8 • 2WD • AUTOMATIC
AHANIX1989
[1996 Dodge Ram B2500 Full-size conversion van]
Flash floods through mid-Wisconsin recently, I was driving home from work and didn't see a lake ahead of me. Water splashed into the intake and the van died. I didn't try restarting it, let it sit until the next day, when we came back.... plenty of water at the filter, so we removed the spark plugs and cranked it. Plugs were wet and water shot out. After about 5 minutes of intermittent cranking, we'd only get fuel mists out of all eight cylinders. Tried starting again, still wouldn't run, found the intake is full of water.
Any hope if I remove the intake manifold and dry it off? I have a Haynes manual to help me.
Video of it cranking:
http://www.youtube.com/watch?v=1QKk3Cdxv80
Jun 13, 2008 at 6:26 PM
BMRFIXIT
  • 19,053 POSTS
check for spark
I would check for spark at the wires and check dist. Cap if wet replace.
Jun 13, 2008 at 11:22 PM
AHANIX1989
It's getting a spark, it's getting fuel, and I'm assuming it's getting compression. Right now there's just no air because the intake is full of water
Jun 14, 2008 at 2:01 AM
BMRFIXIT
  • 19,053 POSTS
use a shop Vac to get the water out
or remove the manifold
Jun 14, 2008 at 7:05 AM
