1996 Dodge Ram V8 Four Wheel Drive Automatic
I just put oversized tires on my truck and they are rubbing. I have just ordeed a 2.5" leveling kit which consist of a 2.5" spacer that goes under the front spring, but my question is about the rear lift blocks. My truck already has a 3" lift from factory, so if I order a 2.5" set of lift blocks for the rear, will they stack on top of the already installed 3" blocks or do I need to order a set that are 5.5"s? I have seen a picture of the 5.5" set and it looks like they are a 2 piece set, that is why I am asking about stacking the 2.5" set on top of the already installed 3 " set. Or should I just order the 5.5" set so I will have U bolts that are long enough?
SPONSORED LINKS
Saturday, February 6th, 2010 AT 7:39 AM
