1996 Dodge Ram Radio,power door lock,rear mirror and dome l
RAMUSTANG
Electrical problem
1996 Dodge Ram V8 Two Wheel Drive Automatic 117xxx miles
Suddenly my radio, door lock, power mirror and dome light stopped working. what would cause of this? Thanks for the help..
Apr 30, 2010 at 2:06 AM
KHLOW2008
  • 41,812 POSTS
Hi ramustang,
Thank you for the donation.
Since so many items failed at the same ime, the most likely cause would be a blown fuse.
Check the power distribution center fuses # 19/20 ( 15 A ).
May 1, 2010 at 12:11 AM
RAMUSTANG
Hi KHlow2008 Fuse #20 it the one.. But now when i put the new fuse that one blow too.
May 4, 2010 at 2:38 PM
KHLOW2008
  • 41,812 POSTS
We have good news and bad news.
Good news ia we know where to start looking for.
Bad news is there are so many components using the fuse and any of them could be the culprit.
We would have to do the elimination process to locate the source.
Was anything done prior to this occuring?
Does the fuse blows immediately when a new one is installed or it blows only when a component is operated?
May 5, 2010 at 4:15 AM
RAMUSTANG
Nothing was done... the only thing i remember it that i broke the connector on the wood light that illuminates the engine compartment the same day that the fuse blow the firth time. well, i replace the fuse Monday morning and melted Tuesday night.. and came home immediately replace the fuse and that one melted immediately i put that sucker up...
May 5, 2010 at 2:23 PM
KHLOW2008
  • 41,812 POSTS
Bingo, We got it.
The fuse is also linked to the underhood illumination bulb. Check the bulb and its holder for shorting. If the bulb is broken, use a plier to remove the filament to prevent it from shorting.
May 6, 2010 at 3:42 AM
