1996 Dodge Ram no spark at operating temperature
1996 DODGE RAM
165,000 MILES • V8 • 4WD • AUTOMATIC
BBBAAADDD
My 96 dodge ram loses spark once everything under the hood gets warm, If I drive it down the road it is fine, when I come to a stop and it idles for a few minutes it dies no spark. If you leave it sit 45 minutes it will fire right up and be fine again till you stop moving? I replaced the coil and the crank sensor. help?
May 11, 2008 at 11:09 PM
Test the ASD relay and the computer's coil driver-
May 11, 2008 at 11:21 PM
To: rasmataz
Posted: Mon May 12, 2008 3:24 pm
Subject: 96 dodge ram with no spark
what is a coil driver? the computer itself? should I replace the computer? i've tried a different asd relay, thank you
I gave you the ASD relay bcuz it powers the coil -Now the col driver is integrated with the computer-this is the one that switches the coil primary to fire the plugs-
May 12, 2008 at 9:37 AM
BBBAAADDD
so the coil driver is the computer? I can get as used computer from salvage yard for 125. should I try that? or where is the coil driver?
May 12, 2008 at 2:49 PM
The coil driver is integrated with the computer. Its your shot
May 12, 2008 at 9:48 PM
