1996 Dodge Ram HELP QUICK
154,000 MILES • V8 • 4WD • AUTOMATIC
CARTER10133
i have a dodge truck that will shift into reverse but will not move anywhere. drive works fine.. is there a way to just adjust the reverse in the transmission or do i need to replace the whole thing?
Aug 30, 2010 at 9:18 AM
HMAC300
  • 48,601 POSTS
have a pro check this if your fluid is full and not burnt brown or so. It probably is the clutch pak may be burnt up or the seals are hard and not working.
Aug 30, 2010 at 11:39 AM
