1996 Dodge Ram heater core
MMORTON17
Engine Cooling problem
1996 Dodge Ram
How do I replace the heater core in my 1996 Dodge Ram Van?
Mar 22, 2009 at 4:16 AM
CARADIODOC
  • 34,415 POSTS
Why do you want to replace it? You didn't bother to describe the symptom you're trying to solve. This is definitely not a do-it-yourself project unless you're prepared to recover the refrigerant and disconnect the air conditioning system, remove the steering column and dash board to remove the heater box.
Disconnect the actuators and the electrical and vacuum connectors. Pull the heater box out, separate the two halves on a workbench, replace the heater core, reseal the box and check for proper operation of the temperature and air flow doors. Reinstall the heater box, dash, and steering column. Reconnect the AC hoses and pump the system into a vacuum for at least 30 minutes while it's 70 degrees or warmer, then recharge the system with the correct amount of new refrigerant.
This job should take a professional about 4-6 hours. It would take me about two days. Are you sure you want to tackle this job?
caradiodoc
Mar 25, 2009 at 4:48 PM
