1996 Dodge Ram heater
105,000 MILES • V8 • 4WD • AUTOMATIC
MIKEY61046
i just replaced my water pump and altanator and now it wont heat up my inside of my truck its like a luke warm it doesnt get hot and it wont defrost my windows the temp.gauge reads just a little higher than normal whatcan i do to fix this
Mar 8, 2008 at 10:14 AM
SERVICE WRITER
  • 9,123 POSTS
Couple thoughts:
The thermostat may be sticking open and not allowing it to heat up like it's supposed to.
There is an air pocket that may be in the heater core.
The water pump may be a problem.
Questions:
What liter size is the engine?
Is the water pump new or reman?
Was the heat present before the work?
Did you overheat it at all, gauge going into the red?
Mar 8, 2008 at 10:18 AM
MIKEY61046
[quote:a105323ffd="Service Writer"]Couple thoughts:
Questions:
What liter size is the engine?its a 317
Is the water pump new or reman?new
Was the heat present before the work?yes
Did you overheat it at all, gauge going into the red?[/quote:a105323ffd]no
Mar 8, 2008 at 10:21 AM
SERVICE WRITER
  • 9,123 POSTS
Feel the heater hoses at the core are they hot going in and hot coming out or just luke warm coming out?
Should be hot on both sides.
IF you have access to a heat temp gun shoot the rad from top to bottom as there have been a common thread of radiators plugging at the bottom.
Did you copmpare the new pump to the old one to make sure the fins were not a reverse directional?
Mar 8, 2008 at 10:41 AM
MIKEY61046
[quote:496fa51a73="Service Writer"]Feel the heater hoses at the core are they hot going in and hot coming out or just luke warm coming out?
Did you copmpare the new pump to the old one to make sure the fins were not a reverse directional?[/quote:496fa51a73]
the hoses are hot on both sides
whats a heat temp gun
and the repair shop put the water pump on i didnt
Mar 8, 2008 at 10:45 AM
SERVICE WRITER
  • 9,123 POSTS
Take it back to the shop, that is thier baby to figure out.
They may need to bleed the system. Hopefully they didn't put a reman one on as the fins can be corroded and not changed by the reman company or a reverse fin put on.
Mar 8, 2008 at 10:55 AM
