1996 Dodge Ram hard starting
SALFORDBIL
Electrical problem
1996 Dodge Ram 6 cyl Two Wheel Drive Automatic
sometimes my truck wont start if i lift the hood and tap the fuel pump relay with my finger it will start, i changed the relay it made no difference
Feb 12, 2009 at 3:55 PM
  • 110,251 POSTS
Hi:
I would recommend checking fuel pump pressure. Many parts stores lend or rent the gauge. If you need directions, watch this video:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Also, when the problem happens again, make sure it is getting spark to the plugs. Has the check engine light ever come on when this happens?
Feb 13, 2009 at 9:27 AM
