1996 Dodge Ram getting too much fuel
MOTOMIKEY270
Engine Performance problem
1996 Dodge Ram V8 Four Wheel Drive Automatic
I have a 1996 ram with a 360. I have replaced every sensor except the tps, map, and air temp including a used pcm and it is still having the same problem. It is getting too much fuel. It is running 51 psi consistantly and is in time. it will start and run for a few seconds till it floods out and dies. any ideas? looks like the fuel pump assy has already been replaced.
Feb 17, 2010 at 10:29 AM
  • 110,248 POSTS
Have you replaced the temp sensor?
Feb 19, 2010 at 2:33 AM
MOTOMIKEY270
yes, both the temp sending unit and the engine coolant temp sensor. thanks for the reply.
Feb 19, 2010 at 10:53 PM
MOTOMIKEY270
got it running, stopped up converter
Feb 21, 2010 at 9:47 AM
