Am smelling a gas leak when I step outside of the truck. not under the hood or near injectors. more towards the fuel pump. smell the gas sometimes when I park after driving. sometimes not then. sometimes when i put key in ignition and let fuel pump catch up, or when starting.
Is taking longer and longer for engine to catch during ignition. starter turns over, but is taking a second of so now for fuel to makes its way to wherever. started a few weeks ago. took half a second. now it takes a full second.
Sometimes this is still not the case.
am thiking it is the fuel pump or the fuel filter? near the pump, or mayeb some type of exhaust valve near the same. Also thinking I should just change it all out.
wonderign what a real mechanic thinks.
Jul 18, 2009 at 10:53 AM
