My pickup stalls randomly?
14,300 MILES • V8 • 4WD • AUTOMATIC
EMERADO
my pickup stalls randomly. I have a new fuel pump,distributor cap, rotor,spark plugs,battery,thermostat,spark plug wires,water pump,and a new fuel cap.It was put on a code checker and it came up as no codes.Somebody mentioned the crank sensor. How do you check that if it does not come up on the decoder,or is it something else
Jul 16, 2010 at 4:21 AM
DOCFIXIT
  • 18,828 POSTS
Hi
When it stalls does restart right away? do it slowing down? braking?any other
This guide can help
https://www.2carpros.com/articles/engine-stalls
performance problems?
Let me know
Jul 16, 2010 at 4:46 AM
EMERADO
When going slow in town it will stall. It did it 2 weeks ago and it has been fine since. Except this morning it started again. Most of the time it starts back up,but this morning it would start then quit then it wouldnt start so i left it a couple hours. It started up quit started quit and now its running fine.2 weeks ago when it did it we were going 60mph and it didnt stall but acted like it wanted to stall i had the cruise control on and it started to cut out but worked itself out.I have put 2 cans of sea foam threw it since then
Jul 16, 2010 at 5:08 AM
DOCFIXIT
  • 18,828 POSTS
O.K. need to narrow down possibilities. Next time it stalls and won't restart check for spark at plug if good then spray carb cleaner into throttle crank does it fire. Let me know
Jul 16, 2010 at 5:30 AM
RGULLETT
Have you figured this out yet? My 95 Ram does the same thing. I found that when it is not running I do not have any spark. I have replaced the crankshaft position sensor, camshaft position sensor, asd relay, coil and computer but still do not have a spark. Mine started out acting like it was out of gas, it would stall when you stepped on the gas pedal and if you released the gas pedal it would recover but since then it has gotten worse. It now stalls at any time. It can be driving on the road at 70 mph or stopped at a red light it just dies. It usually starts back up after it has cooled off but not always.
Apr 9, 2011 at 9:28 PM
DOCFIXIT
  • 18,828 POSTS
Is check engine light on? when it stalls is there no spark but have fuel ie. can hear pump run?
Jul 22, 2011 at 6:13 AM
